Both ends of the Driveshaft...?
Dedicated to discussion of the synchromesh, variable pitch dynaflow, and flight pitch dynaflow transmissions.
Postby RoadMaster75 » Mon Nov 19, 2007 10:04 am
Hi Folks
Well, winter is bearing down out here on the tundra and I would like to tackle my
clunky U-joint noises in my Roadmaster 75. I'd like to drop the whole torque tube
as prescribed in the shop manual and rebuild and replace EVERYTHING at both ends
of the driveshaft, as long as I'm going to this amount of work.
My questions are:
1.) Can anyone enlighten me to ALL the parts needed? ( seals, gaskets, u-joints,
hardware, etc) For all the stuff at the end of the trans as well as at the Differential?
Is CARS,Inc. a good choice to supply these or...?
2.) The shop manual is not intuitive to me..! Has anyone done this job themselves?
Any words of wisdom as to the process, tricky stuff, stuff not covered in the shop manual.
Also, thinking of replacing the weakening springs at this time...Sources?
I'll have it on the lift; no more cold concrete for this 58 Fan!
Much appreciated!
Mike "RoadMaster 75"
1958 Roadmaster75 - Unrestored w/ 40,000 orig. miles
1949 Willys-Overland Jeepster - Buick V6 power
1951 Chevrolet 1/2 ton Panel truck - 455 Stage One Buick power
1978 Cadillac Eldorado "Biarrtiz" - 22,500 orig. miles
RoadMaster75
Re: Both ends of the Driveshaft...?
Postby HotRod58er » Wed Apr 23, 2008 10:17 am
well I do have 2 NOS U joints for my 59 but they are the smaller ones if you need one I can sell it for $35 plus S&H. I bought it from CARS and just have them sitting in the dining room still! I know with torque tube you will need the 2 gaskets for the front and back of the tube, and while I was at it I would also lube the rear axle.
Reverance for the past-ensures the future
Cars
1997 Buick Riviera (yes its supercharged)
1959 Buick LeSabre 4 door sedan (45,000 original miles)
HotRod58er
Return to Transmissions
