by 58limited » Wed Aug 15, 2007 12:57 pm
Tory,
Welcome to the forum. I never received your first post about your difficulty registering, but I just now (at 12:45pm) received your "Nevermind, I figured it out" reply. I'm hoping this new forum will eliminate the lost or delayed posting that I always ran into on Yahoo.
Now, Variable pitch dynaflows have a kick down in order to downshift for accelerating power when passing, or just flooring the gas.
The variable pitch in fact has three gears: First (low), Second, and Third. The car basically always runs in third gear - this is how it has the smooth accelration with no shift being felt. When you floor it while driving, the transmission will kick down into second and give you a boost in power - it will throw you back into your seat. From a stop, you can manually shift into first with the gear shift, accelerate until the engine sounds like it needs to shift - like in a regular car - and upshift into drive. The transmission should shift into second, then third when you do this.
Now, don't try this at home as I'm sure its not good for the transmission, but sometimes at a light some kid will rev his engine thinking he can beat me in a race. I will shift into low, floor it when the light changes, and I can give that kid a run for the money. I up shift to drive when the speedo reads 35-40mph. I don't win (the car is 5000 pounds) but it impresses them. I have even spun the tires a time or two - not bad for a Limited with a variable pitch.
