Model 58-41 (4dr 6 pass sedan)
Style 58-779 (Buick Special 4 dr Sedan)
Body BT1722 HELP! i NEED HELP ON THIS ONE...
Trim 446 (Gold Pattern -White Cordaveen)
Paint 55 (Polar Mist top & bottom)
Acc N1-P3 HELP! I NEED HELP ON THIS ONE...
vin: 4E8010123 Arlington Texas car.
Spesh has power brakes, green glass, padded upper dash and air conditioning. I understand these are pretty good options for a 41 Series.
If there is any help on the Body and ACC codes I'd greatly appreciate it.
Thanks for having me in your group!
Kevin Mahoney
The journey begins...God speed, Spesh!
MOD 58-41
STYLE 58-4469
BODY BT 1722
TRIM 446
PAINT 55
ACC N1-P3
4E8010123
STYLE 58-4469
BODY BT 1722
TRIM 446
PAINT 55
ACC N1-P3
4E8010123
Re: The journey begins...God speed, Spesh!
Welcome to the group, Kevin.
The body number is the production serial number of the body. The prefix letter denotes the plant in which the body was built. In this case BT= Arlington, 1722nd body built.
The style number you posted does not match anything in my book - it should read 58-4469 for a Special 4 door 6 passenger sedan. The style number breaks down like this: 58 = model year, the first 4 = Buick Motor Division, the second 4 = series 40 (Special), and 69=four door sedan body style.
I have not been able to find any break down of the ACC code - I would also like to know this info. I suspect it is an options package (in your case probably something like power breaks, automatic tranny, air conditioning). A/C was a fairly rare option, especially on the Specials. All air conditioned cars came with the green tinted glass as part of the A/C option, as well as an air duct that goes from the core support to the back of the generator to cool the generator in order to allow for maximum amp output to run the system.
Here are some pictures of my project. Started this past August 2009
- Attachments
- I'm dead in the water. Danny can make one, I would like to have a replacement! Any suggestions?
- (96.12 KiB) Downloaded 2567 times
- here's the frame
- (79.63 KiB) Downloaded 2568 times
- body comes off
- (73.4 KiB) Downloaded 2566 times
- landed
- (191.62 KiB) Downloaded 2567 times
- Away it goes
- (116.75 KiB) Downloaded 2566 times
MOD 58-41
STYLE 58-4469
BODY BT 1722
TRIM 446
PAINT 55
ACC N1-P3
4E8010123
STYLE 58-4469
BODY BT 1722
TRIM 446
PAINT 55
ACC N1-P3
4E8010123
Progress pictures October-November 2009
- Attachments
- frame like the rest of the body after sand blast, red epoxy prep to all bare metal
- (52.95 KiB) Downloaded 2490 times
- undercarriage. Chose to have the undercarriage finished in bed liner material. Mine is going to be a driver-
- (72.98 KiB) Downloaded 2492 times
- installed
- (65.19 KiB) Downloaded 2491 times
- after sand blast
- (45.49 KiB) Downloaded 2492 times
- spare tire tub from Weatbelt Buick arrives
- (52.34 KiB) Downloaded 2490 times
MOD 58-41
STYLE 58-4469
BODY BT 1722
TRIM 446
PAINT 55
ACC N1-P3
4E8010123
STYLE 58-4469
BODY BT 1722
TRIM 446
PAINT 55
ACC N1-P3
4E8010123
con't
- Attachments
- patched
- (45.86 KiB) Downloaded 2483 times
- floor rust through.
- (37.04 KiB) Downloaded 2483 times
- body after blasting in the red epoxy
- (47.35 KiB) Downloaded 2481 times
- frame finished, probably going to regret not having the cross-member dent fixed
- (104.61 KiB) Downloaded 2483 times
- frame in primer after all rust pits filled. I elected to leave the cross-member dent alone-due to budget overrun. I did it with a floorjack when long long time ago
- (56.47 KiB) Downloaded 2485 times
MOD 58-41
STYLE 58-4469
BODY BT 1722
TRIM 446
PAINT 55
ACC N1-P3
4E8010123
STYLE 58-4469
BODY BT 1722
TRIM 446
PAINT 55
ACC N1-P3
4E8010123
that's it for 2009...tax returns, maybe another refi in order for 2010?
- Attachments
- blocking the body
- (79.31 KiB) Downloaded 2480 times
- floor fixed
- (58.36 KiB) Downloaded 2479 times
- front floor
- (63.07 KiB) Downloaded 2478 times
MOD 58-41
STYLE 58-4469
BODY BT 1722
TRIM 446
PAINT 55
ACC N1-P3
4E8010123
STYLE 58-4469
BODY BT 1722
TRIM 446
PAINT 55
ACC N1-P3
4E8010123
nice, your project is really coming along. did you fabricate that section of the trunk lip yourself?
Thanks. The trunk lip came from a Century parts car I picked up in Ohio. I'm having all the metal work done by a pro.
MOD 58-41
STYLE 58-4469
BODY BT 1722
TRIM 446
PAINT 55
ACC N1-P3
4E8010123
STYLE 58-4469
BODY BT 1722
TRIM 446
PAINT 55
ACC N1-P3
4E8010123
